Browse Forums General Discussion 1 Feb 19, 2009 11:11 am After some opinons here?
We are doing up a rental property that has been basically gutted, except for stand alone stove and bath tub. It the kitchen after ripping out old flooring, there is alot of animal poo. Not sure if it roach, mice or both. There has been no signs of any living creature in the house. Should we be looking at getting it pest control done? or don't worry? Best to do before painting and flooring ect or doesn't matter when. Re: pest control. Is it needed? 2Feb 19, 2009 11:47 am I wouldn't worry about it personally, the poo might've been there for ages and the animals might have long gone...
I personally would wait to see if you get problems with actual creatures before forking out for that. Can't comment on whether it's better to do it while the house is gutted though, might be worth taking into consideration. We had ours done yesterday; it was a pretty simple process and our house is fully built Looking forward to no more ants! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: pest control. Is it needed? 3Feb 19, 2009 12:05 pm Getting it done before you move in would be much simplier and easier.
IF you have to get it done afterwards, you need to re-wash dishes, move stuff out of the way, etc. But doing it beforehand means it will take them less time and cause less work for you. You could even just go buy surface spray from woolies and spray that around the corners, will cost very little (~$5 a can or something?) and put up a barrier. Re: pest control. Is it needed? 4Feb 19, 2009 12:08 pm Hellman109 IF you have to get it done afterwards, you need to re-wash dishes, move stuff out of the way, etc. we didn't have to wash dishes. he only did around the skirting boards, said it was not legal to be spraying it on food preparation surfaces. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5059 4 1890 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7488 |
