Browse Forums General Discussion 1 Feb 13, 2009 12:56 pm I just have a bit of a plumbing question for those in the know.
If there is a laundry downstairs, and directly above this a kitchenette is desired at a future date, how difficult is it to run hot and cold water and the waste straight up the wall in the following scenarios? a) in an existing house built on a slab b) during a build as an "add on" without doing it officially in the quote (i.e. just get the plumber to run the pipes for later fitout as a cashy) or is this too much of a drama? c) make provision for future pipes during the build without actually running them What would be involved in each of those cases? Hope this makes sense. Thanks in advance, Jo I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Plumbing question. 3Feb 13, 2009 2:35 pm C'mon Joles don't keep us in suspense.
Have you changed builder, swapped to a 2 storey design? One of those 2 storey houses with an ensuite to every bedroom (I've seen Carlisle's version) would suit you well. Look forward to hearing more, Dale. Building the Monaco 32 with Carlisle Homes Check out our blog for photos and progress reports: http://www.beigefreehouse.blogspot.com . Re: Plumbing question. 4Feb 13, 2009 3:08 pm One little question and you all jump to conclusions.
Just an in theory question concerning some plumbing. Nothing to report at this stage. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Plumbing question. 5Feb 13, 2009 3:12 pm I know we are stickybeaks but you have been quiet for the last few days so I think all our imaginations are running away with us. Sorry we won't keep bothering you ........but if there is something you need to tell us feel free LOL
Some things are worth waiting for. Re: Plumbing question. 6Feb 13, 2009 3:15 pm If and when there is something to report, you'll be the first to know.
Oh and I am the world's biggest sticky beak , so I completely understand! I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Plumbing question. 7Feb 13, 2009 3:27 pm joles If there is a laundry downstairs, and directly above this a kitchenette is desired at a future date, how difficult is it to run hot and cold water and the waste straight up the wall in the following scenarios? a) in an existing house built on a slab Easy but slightly messy... joles If there is a laundry downstairs, and directly above this a kitchenette is desired at a future date, how difficult is it to run hot and cold water and the waste straight up the wall in the following scenarios? b) during a build as an "add on" without doing it officially in the quote (i.e. just get the plumber to run the pipes for later fitout as a cashy) or is this too much of a drama? Very easy not messy... but you would need to let the supervisor know. joles If there is a laundry downstairs, and directly above this a kitchenette is desired at a future date, how difficult is it to run hot and cold water and the waste straight up the wall in the following scenarios? c) make provision for future pipes during the build without actually running them Waste of time IMO - may as well run the pipes. Further - you are unlikely to get planning permission for a kitchenette - so say it's for a wet bar. What about power? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6173 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7043 5 3784 |
