Browse Forums General Discussion 1 Feb 06, 2009 12:28 pm I am about to start renovations to the rear of a workers cottage. Unfortunately, one half of the rear of the house is on a concrete slab and the other half is joist/bearers. I am also planning a small extension on the side of the house that currently sits on the concrete slab.
Would it be better to concrete the remaining sub-floor space? or would it be better to remove the current slab and put everything on stumps? The front of the cottage has recently been re-stumped. Would there be issues going forward if the front is on stumps and the rear is on a slab? If you're in a flood zone, not only are you dealing with the importation of fill and laying it down in 150 lifts to achieve compaction, you're going to have to consider… 4 5532 if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7344 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
