Browse Forums General Discussion 1 Feb 04, 2009 5:40 pm We're building on a vacant block with existing neighbours - we were told that we'll need to protect the fence in some way from small things, such as splashes from the brickies when they use the mortar.
I had thought of just getting a few rolls of plastic and covering it up on our side, but don't know if that's going to trap moisture, cause damage to the fence, etc... Should we look at some form of protection, or is not going to be worth the cost? What would people recommend we use if we wanted to go ahead with it? Re: Protecting a colorbond fence during construction? 2Feb 04, 2009 7:01 pm We cover windows in plastic for the same reason. It works fine.
Be careful with anything adhesive that it doesn't stay on too long - it gets awful hard to remove after a few weeks. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Can you give advice on how to get missing certificates needed for a form 21? Our bank requires us to provide one but we are missing 4 building certificates from our first… 3 71805 1 62016 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98678 |
