Browse Forums General Discussion 1 Jan 30, 2009 6:15 pm do you think a house with roof tiles will look funny if we use a colorbond roof for a double carport we are adding?
i really like the look or colorbond but too expensive to change existing tiled roof.. do u think this will look out of place and like an "add on" rather than matching Re: colorbond roof for carport tiled roof tiles for house 2Jan 30, 2009 6:31 pm personal I would pefer them to match but as its already there I guess you have to go with what you can get and afford,but you could pick a colour very close match I think that would look ok it also depends on how close to the house too finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: colorbond roof for carport tiled roof tiles for house 3Jan 30, 2009 6:33 pm a few houses across from where i live added metal roofed carports and it didnt look out of place at all, just do the very similar colours as suggested Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: colorbond roof for carport tiled roof tiles for house 5Jan 30, 2009 8:14 pm Go for a drive around and see if you can find anything similar in the neighbourhood....
I personally think it looks like an add on, especially if you get a colour that is close to the tiles... If you do go different, I'd suggest a different colour, but one that will complement the house... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: colorbond roof for carport tiled roof tiles for house 7Feb 01, 2009 6:50 am We did it and matched the colourbond roof colour to the tile roof colour which we had resprayed.
I was hesitant at first also because it was going to be so obviously different and as you can see it is right next to the house. Iknew the type of garden my husband was planning though and knew that would be the feature of our home, not the carport. Hope these photos help, they are the best I had. Andrea Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ **I can't believe how much teh garden has grown! Re: colorbond roof for carport tiled roof tiles for house 9Feb 01, 2009 7:59 pm No we haven't bricked around it, it remains open. We are going to build in one side to use for storage.
We used a kit from Stratco, my husband and father built. Their reccomendation would be to read all instructions prior to starting! Good luck Andrea No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4999 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2610 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10369 |
