Browse Forums General Discussion 1 Jan 27, 2009 8:05 pm Hi,
I am being given the run-around by each and every pool builder who is tendering on our block. Basically, we have 2 small (ish) Gums which are going to be close enough to the intended pool position to be a concern. Both gums are roughly 7m tall. One is right on the pool boundary/fence line, and will come out, but the other is 6.5m from the pool edge. Are gums a problem (apart from the leaves)? I heard that they are serious water seekers, and their roots can do big damage in years to come. Is there a difference between fiberglass or concrete pools when it comes to root prevention? Just wanted to hear the opinion from people who aren't pool salesmen! Thanks, Jonathan Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Re: Pools and distance to the nearest gum 2Jan 27, 2009 8:17 pm Hi Jonathan,
Can't speak about gums in terms of pools, but getting the approval to remove from council can cause problems. Not sure how your council 'values' gum trees - if you haven't already, you might want to research. Cheers Bel Still not in. Don't ask!? Re: Pools and distance to the nearest gum 3Jan 27, 2009 8:53 pm Hi Bel,
Council shouldn't be a problem to remove the one tree. It's the other one that I need to check on - we'd actually like to retain the tree, but just worried about the proximity to the pool. Jonathan Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Re: Pools and distance to the nearest gum 4Jan 28, 2009 7:25 pm i know that gums can cause serious problems with plumbing as they go after the water a friend had the problem with the same not cheap to fix.I live on 5 acres and any gum close by to my house was removed and replaced with more suitable tree that do not cause a problem to house and up coming pool finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Pools and distance to the nearest gum 5Jan 28, 2009 8:41 pm Thanks to all for the advice on this. I had an arborist out to look at the trees today and I got the full run down re CRZ (critical root zone), PRZ etc etc. We will put in a DA for it to be removed.
Jonathan Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Re: Pools and distance to the nearest gum 7Jan 28, 2009 8:57 pm Ha Ha LOL I'm a south african so you'll need to throw in a bit of that twang to add to the confusion Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com 6 4323 Found the answer. The recommended distance is .... 1 5955 Hi We have Hybrid Spotted Gum Hp0995 from carpet call. It turned out to be very dark and rough. Is there any polish or product we can use to make it shinier ? 0 9174 |
