Browse Forums General Discussion Re: pergola building 2Jan 27, 2009 5:59 pm depends on your truss's as to how to attach it
if you are attaching it to your house do you really want to build it your self if you dont know what your doing imagine a massive storm and the pergola collapsing because it hasnt been constructed correctly or have it fail and kill someone thats why building codes, building licences, engineering specs and permits etc are there Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: pergola building 3Jan 27, 2009 7:26 pm Your off to a bad start if your thinking of attaching it to metal fascia.
Uncovered decks are relatively easy for the novice builder, a pergola on the other hand needs a reasonable amount of building knowledge, as davinci said the downside to poor construction can be fatal Re: pergola building 4Jan 27, 2009 9:24 pm At the very least pick up the "Deck and Pergola" book by Allan Staines from Bunnings - it has a wealth of info on specifications, construction methods etc, which should reduce your chances of building a death trap. Also suggest getting onto *.com.au for more detailed help.
Good luck! I guess God didn't use subbies... Re: pergola building 5Jan 28, 2009 8:57 am Attaching to the metal fascia can be done only if there is solid nogging permanently fixed in behind for fixing your brackets to. Being a structural element you will need to submit your plans to council for approval. If you decide to sell you will need the approval anyway.
Regards Paul Is there a building permit? RU in Victoria? What is the value of the building contract? 1 4760 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 24883 i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 5184 |
