Browse Forums General Discussion Re: Clear Anodised Windows? 2Feb 03, 2007 4:20 pm I think it means, just a normal clear glass in the anodised windows.
(Anodised) your colorbond colour. As opposed to safety glass. Ring them on Monday, just to verify this. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Clear Anodised Windows? 3Feb 03, 2007 8:08 pm Clear anodised windows could mean the window frames are anodised (an electrically applied anti-corrosion coating) in clear, meaning the frames are a natural aluminium colour.
I would definitely check what they actually mean. Re: Clear Anodised Windows? 4Feb 03, 2007 9:16 pm ![]() Clear anodised windows could mean the window frames are anodised (an electrically applied anti-corrosion coating) in clear, meaning the frames are a natural aluminium colour. I would definitely check what they actually mean. That is exactly what it means. The frames are electrically coated with a clear anti corrosion material. If all you can see are obstacles, you have lost sight of the goals Re: Clear Anodised Windows? 6May 13, 2010 12:31 pm I realise you've already received an answer, but I will just confirm that clear anodised is a natural aluminium colour, with a clear coating. They look a little matt, at least compared to the other silver-coloured aluminium frames that are available.
They are actually one of my favourite window frame colours as I think they blend well with most wall colours (assuming you aren't painting your house an extremely dark colour). My parents are building at the moment and have chosen clear anodised for all of their windows, and their exterior paint is a greeny colour - Bushland something, perhaps? Half of the windows are in so far and it looks great. And yes, clear anodised is generally a little more expensive than the coloured powdercoated aluminium. Re: Clear Anodised Windows? 7May 13, 2010 2:10 pm ![]() i found out today clear anodised aluminium frames are more expensive than standard powdercoated aluminium frames Annodised prices are indeed higher in Australia, but that is just because that's the way the annodising/powdercoat suppliers have the formula. Overseas the annodised finish is cheaper than powdercoating. We use only powdercoating because annodising is permanently marked by mortar, and because any scratches are nonrepairable. There is more choice in powdercoating, and you can easily repair it. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 i dynabolted a little steel arm to external brickwork that only allowed awning window to open less than 10cm 2 4900 ![]() Our house was built in 2008 It has birch white windows has rendered walls. We are looking to repaint everything inside and out. I'm wondering what colour schemes have… 0 2713 The reason that double glazed windows perform so well as insulators is not in the glass, it is in the airgap. https://www.homeone.com.au/articles/doo ...… 20 9051 ![]() |
