Browse Forums General Discussion 1 Jan 11, 2009 10:49 am Hi There Guys and Girls
A friend of mine is contemplating a move from Melbourne to Bendigo which may possibly take place within 10-14 months. She is quite fond of bendigo but is unsure of the ''Nicer'' locations as far as living in. Now I am hoping that some of you may be able to offer abit of advice as to where the nicer suburbs are as well as possible suburbs to avoid My friend and her hubby are yet to decide whether to build or buy an already established home. Any advice,suggestions or comments would be most appreciated. Thanks Re: BENDIGO - Advice on the areas of Bendigo 2Jan 11, 2009 5:32 pm Personally i think the better areas are:
-Spring Gully (I'm biased - building there now) -Maiden Gully -Bendigo (some of the areas in town) -Golden Square (depending on what part) I'd avoidL -California Gully -Long Gully -Eaglehawk -Kangaroo Flat Re: BENDIGO - Advice on the areas of Bendigo 3Jan 11, 2009 8:43 pm I would agree with MBBN but including suburbs like Kensington, Strathdale, Flora Hill, Strathfieldsaye etc. Generally if you stick to the suburbs east of the main road through town you can't go wrong. Re: BENDIGO - Advice on the areas of Bendigo 4Jan 12, 2009 10:41 am What they said, basically. Stay east of the city not west, says my hubby who originally hails from Bendigo. Building our dream H3nl3y home together House: Cott3sloe Modifications: Extended ensuite, grand dining, grand rumpus, Bedroom 4 option, two plus garage Frame done, roof tiles are on, brickes start this week! Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17923 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 |
