Browse Forums General Discussion 1 Jan 26, 2007 12:31 pm HI there, I'm new to the forum here, and just want to say thanks for all the great info!
Just a really quick question (and I tihnk I'm in the right section), but what is the minimum ceiling height for bedrooms in Queensland? And also, the minimum height for doorways? Any help would be greatly apprecaited! Thanks in advance, Byakko Re: Ceiling height regulations 2Jan 27, 2007 8:11 am 2400mm ceiling height
1980mm doorways - from memory. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10658 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26163 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1803 |
