Browse Forums General Discussion 1 Jan 03, 2009 8:17 pm We have found a house that we would like to buy. It is a double story with three bedrooms upstairs. Downstairs is the laundry and double garage. At the moment it is too small for us but has the possibility of extension as under the house is a split level slab and I believe the height is legal height for building under.
My question is how much would it cost to add a rumpus and an extra room or two under the house on the existing slab? I think when the people initially built the house they allowed for extensions to be possible. TIA Re: Cost of adding a room/rooms 3Jan 04, 2009 3:34 pm A guy I work with added a big rumpus out the back and it ended up costing around 20k (but he needed to lay concrete from memory).
My sister-in-law is currently building in underneath her Queenslander and she has estimated 60k to owner build in the bottom level (not including the slab), but I'm sure she has a kitchen and bathroom going in too and it's a really large house. HTH Re: Cost of adding a room/rooms 4Jan 05, 2009 7:59 am Don't know if this helps but we were quoted nearly 20k last year to transform our garage into a playroom....
Mez Re: Cost of adding a room/rooms 5Jan 05, 2009 10:30 am galomp My question is how much would it cost to add a rumpus and an extra room or two under the house on the existing slab? I think when the people initially built the house they allowed for extensions to be possible. TIA Generally extensions are going to cost a lot more per square than building clean, especially if it is under or over something. I'd say something like 12-15k per square (9m^2) is reasonable considering building new is like 6-8k per square. The extra cost is to cover contingency because of the unknowns when dealing with something already built. http://www.homedesigndirectory.com.au/c ... age2.shtml Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4672 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13694 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9149 |
