Browse Forums General Discussion 1 Dec 29, 2008 2:16 pm Hi, we are considering rendering a two-storey white painted brick house and worried about a) whether the paint will stop the render 'sticking' and b) brick lines showing through the render as we've seen on other houses. Have been reading discussion about foam cladding then render - can anyone advise whether this is a good and cost-effective option or whether there is a better way? Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 |
