Browse Forums General Discussion 1 Jan 22, 2007 5:05 pm Hello,
I'm looking for an archive or resource for house plans as I wish to find the plans that match my house. It is a pretty standard design as far as I'm aware. I think it is an A.V. Jennings house built in 1981. Any ideas on where I should start? Thanks. Re: Finding a common house plan 2Jan 23, 2007 7:48 am I don't know of any online resources that would help but if you send me a sketch of the floorplan with approx measurements & an image of the exterior I can look through Jennings brochures from the 80's.
You could check with your local council building dep't. If it's a Jennings home [ & they have the submitted plans } Jennings usually had the name of the design on the drawings. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. 3 2639 Hi, I am new to the grp. I am building new house on land size of 326 sqm with frontage of 10.7. Attached is the draft plan, looking for feedback and inputs from the… 0 2990 Old Home Restoration / Renovation Your lintel will need to rest on something and it is usually at least 250 mm of brick, it doesn't seem there is enough space on the right side for it, as the opening is… 3 2510 |
