Browse Forums General Discussion 1 Dec 23, 2008 8:39 am Hi,
Can anyone tell me what the rules are with using pine framing timber with factory spliced joints. I know it can be used for wall studs but not sure if it can used for the other framing members. For example if pine timber is rated MGP10 but has factory spliced joints can you use this timber for wall plates? Or roof battens, lintels etc. Cheers Re: Using framing timber with spliced joints 2Jan 10, 2009 8:17 am Best talk to your supplier on that one... Or check out AS1684....
I suspect if it's graded as MGP10, then you could use it.. Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10216 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7471 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5860 |
