Browse Forums General Discussion 1 Dec 17, 2008 5:38 pm I'm renovating a kitchen and have found that the pantry in possibly built in with structural framing on each side. Am I able to knock this framing out, or will the roof sag and my world turn upside down? If I knock the frames out, I'll be left with a gap of 5000mm from wall to wall, without any other internal structural support. Any help will be really appreciated. Re: minimum internal wall spacing distance, without support? 2Dec 17, 2008 5:52 pm This is impossible to judge, you need a builder or engineer to look at the design and construction. Before you find yourself walking on the ceiling.
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: minimum internal wall spacing distance, without support? 3Dec 17, 2008 8:30 pm You need to determine whether the wall is load bearing or not. If you have a tiled roof there is a substantial amount of weight on your roof - as said, if you don't have the knowledge get an expert or it could be a disaster. Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10939 4 3730 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6908 |
