Browse Forums General Discussion 1 Dec 14, 2008 8:58 pm Hey guys, just wanting some advice on our situation
We are almost at lockup stage so bricks and roof tiles are on and plaster has been put up (in progress), however We had a look at our house today and noticed that in the Master bedroom there was water all over the floor and that the roof has water damage to the plaster and has cracks accordingly... My question is do they need to replace the water damaged plaster??? Or is it a repair issue??? Im assuming the reason for water getting in is because with the facade we have (cladding) which has not been installed yet, the roof tiles are built around the cladding section allowing water to get in with the rain we've had the last couple of days. Thanks in advance. Building Urbanedge Larne 002 Re: Need advice on water damaged plaster??? 2Dec 15, 2008 8:15 am I would also like to know as well
My plaster wall is not cracked yet but was soak with water.. does it need to be replaced? i am also wondering, should the insulation also be replaced? i think they are all wet, can someone advise? Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Need advice on water damaged plaster??? 3Dec 15, 2008 8:34 am Plaster shouldnt get wet. And the recent rain has been extreme. I bet if you went in the roof you will get a better idea of the damage and the amount of water . it could look worse, iif not all water has come through yet.
I would be recommending that all areas effected by water be replaced. I think the batts are not as effected. but i would want to be making sure that they dry out properly. Re: Need advice on water damaged plaster??? 4Dec 15, 2008 8:35 am Plaster shouldnt get wet. And the recent rain has been extreme. I bet if you went in the roof you will get a better idea of the damage and the amount of water . it could look worse, iif not all water has come through yet.
I would be recommending that all areas effected by water be replaced. I think the batts are not as effected. but i would want to be making sure that they dry out properly. Re: Need advice on water damaged plaster??? 5Dec 15, 2008 8:59 am Plasterboard is manufactured by mixing gypsum with water... it starts off wet.
If the plasterboard is damaged, sagging or crumbly, then it should be replaced up to the point where there is no damage. If the insulation is fibreglass then it does not absorb water and when it dries it is fine. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Need advice on water damaged plaster??? 6Dec 15, 2008 9:06 am the insulation is grasswool, will that absorb water? Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Need advice on water damaged plaster??? 7Dec 15, 2008 9:07 am Do you mean glasswool... which is fibreglass - actual glass in fibre form.
This will not absorb water and will be fine when dry... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Need advice on water damaged plaster??? 8Dec 15, 2008 9:53 am Thanks EcoClassic
Yes it is glasswool, spelling mistake.. Properly i need to take a close look for the plaster today and take some pictures.. thanks Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2216 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5038 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5300 |
