Browse Forums General Discussion 1 Nov 25, 2008 8:54 pm Just after any tips or if it's even possible to gyprock over weatherboards? I have a extension on the back of my place that is the laundry which still uses the original weatherboards as the walls and i'm looking to cover them up. Re: Gyprock over weatherboards 2Nov 27, 2008 9:15 pm better off ripping the weatherboards off so you get a nice flat surface for the plasterboard. You'll have the chance to see anything hidden in the wall as well.
If its a laundry I'd use the moisture-resistant plasterboard in there, if not villaboard. 6 11144 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11753 |
