Browse Forums General Discussion Re: Eaves - The Final Verdict - You Decide! 42Nov 18, 2008 7:42 pm russell More floor space? Less cleaning I suppose you must mean for a given block size but that just struck me as funny. As if, when you ask for eaves, the builder goes and cuts 450 mm off the side of every room to create eaves under the same sized roof . A house without eaves is like the Mona Lisa. Eyebrowless and wierd. What did you mean Matt by more floor space? As our house was only going to have eaves on the front facade but then our guidelines stipulated they must be on the east and north side as well. All our builder did was extend the roofline out. It didn't change our floor plan or floor space at all. Re: Eaves - The Final Verdict - You Decide! 44Nov 18, 2008 7:50 pm wakeboardandy russell More floor space? Less cleaning I suppose you must mean for a given block size but that just struck me as funny. As if, when you ask for eaves, the builder goes and cuts 450 mm off the side of every room to create eaves under the same sized roof . A house without eaves is like the Mona Lisa. Eyebrowless and wierd. What did you mean Matt by more floor space? As our house was only going to have eaves on the front facade but then our guidelines stipulated they must be on the east and north side as well. All our builder did was extend the roofline out. It didn't change our floor plan or floor space at all. Aren't setback conditions based on where the roof line ends and not where the footings end? Re: Eaves - The Final Verdict - You Decide! 45Nov 18, 2008 7:55 pm wakeboardandy What did you mean Matt by more floor space? As our house was only going to have eaves on the front facade but then our guidelines stipulated they must be on the east and north side as well. All our builder did was extend the roofline out. It didn't change our floor plan or floor space at all. I chose to build to both boundaries on my block. The facade of my house, based on the width of the block (to a degree) had to be this one. There were 7 options. Had I changed to a house with 450mm eaves I would have had to make the whole house smaller. Take that 450mm around the entire perimetre of the house and I would have lost 27sq metres of floor space and had to pay an extra $15,000.00 for the priveledge. In this case it made sense for me. (That said though I did like the facade .... schhhhhhhhhhhhh ) Re: Eaves - The Final Verdict - You Decide! 46Nov 18, 2008 7:56 pm dymonite69 Aren't setback conditions based on where the roof line ends and not where the footings end? Spot on!!! Hence the above post... Re: Eaves - The Final Verdict - You Decide! 47Nov 18, 2008 7:59 pm The idea is to show the sides without eaves.... The house still appears the same (to me) Re: Eaves - The Final Verdict - You Decide! 48Nov 18, 2008 8:03 pm mattwalker I chose to build to both boundaries on my block. Matt is quite within his right to do this but there is double implication here. Someone might have just lost their solar access because of this. Re: Eaves - The Final Verdict - You Decide! 49Nov 18, 2008 8:14 pm Quote: I chose to build to both boundaries on my block. We're not allowed to do that here anyway. Council will permit building to one boundary only. I built to boundary on garage side and there are no eaves on side of garage - there are no windows on side of garage anyway and are not allowed to put windows in boundary walls in any case. We also have no eaves at the front but that is so we can have a bullnose verandah across front, which obviously serves same purpose. All other walls have eaves and I certainly think houses look better with eaves (as well as function better). Re: Eaves - The Final Verdict - You Decide! 50Nov 18, 2008 8:22 pm Re: Eaves - The Final Verdict - You Decide! 51Nov 18, 2008 8:34 pm Yes, eaves here.
Mind you, I am not totally against the boxy look, to me some eaveless houses look fantastic, but when we were going through the early stages of selecting options for our house, we selected eaves when we discovered that our budget would allow for it. For us, the choice between eaves and brick infills (for example) was a no-brainer. Every house used to have eaves. The only reason they were discontinued as a standard feature by building companies was to cut costs. It had nothing to do with fashion (although Georgian purists might disagree). Re: Eaves - The Final Verdict - You Decide! 52Nov 18, 2008 8:47 pm mattwalker wakeboardandy What did you mean Matt by more floor space? As our house was only going to have eaves on the front facade but then our guidelines stipulated they must be on the east and north side as well. All our builder did was extend the roofline out. It didn't change our floor plan or floor space at all. I chose to build to both boundaries on my block. The facade of my house, based on the width of the block (to a degree) had to be this one. There were 7 options. Had I changed to a house with 450mm eaves I would have had to make the whole house smaller. Take that 450mm around the entire perimetre of the house and I would have lost 27sq metres of floor space and had to pay an extra $15,000.00 for the priveledge. In this case it made sense for me. (That said though I did like the facade .... schhhhhhhhhhhhh ) damn.. 15k... well that would make sense to most people.. I wouldn't pay 15k for them.. Re: Eaves - The Final Verdict - You Decide! 54Nov 18, 2008 9:09 pm The distance between the house on the eastern is far enough that the morning sun touches the garage wall first thing in the morning.
How exactly does that shade my neighbours Lyn? Should I be concerned about the passive solar radiation of the heating the the rear wall of their garage entrance?? Re: Eaves - The Final Verdict - You Decide! 56Nov 18, 2008 9:25 pm I think there's a line that everyone has to be careful of.... there's voicing and discussing preferences ...... and then there's telling people their houses look crap...
You said yourself Lyn those are cheaper end houses, maybe for some families the 3k - 4k was better spent going towards another bedroom to actually live in, than some eaves. Just my 2c. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Eaves - The Final Verdict - You Decide! 57Nov 18, 2008 9:26 pm Lyn This look really bugs me... just wrong!: It bugs you ... not everyone! I would expect to see houses like that in Cranbourne West (having owned a few rentals there) and if all the houses around you are the same why build the Taj Mahal. 'When in Rome....' There is a place in buildings for these designs as not everyone has the same taste. Some times it has to come down to dollars and space. Re: Eaves - The Final Verdict - You Decide! 58Nov 18, 2008 9:26 pm To me I don't think I would buy a house that was obviously "supposed" to have eaves but didn't. To me (and this was even before getting into building) I'd think (rightly or wrongly) they built it on the cheap and if they were too cheap to pay the extra for eaves what else did they scrimp on ?. Its harsh but I think it looks like an incomplete house and that would bother me.
Also I couldn't count the number of people who have said "oh just please build a house with eaves" when I mentioned I was building. It really does bug so many people. EDITED: Its when the looks like its "supposed" to have them where it looks wrong. Some georgian styles don't have eaves and most palaces don't either and none of them look unfinished, its about good design I guess Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Eaves - The Final Verdict - You Decide! 59Nov 18, 2008 9:29 pm joles I think there's a line that everyone has to be careful of.... there's voicing and discussing preferences ...... and then there's telling people their houses look crap... You said yourself Lyn those are cheaper end houses, maybe for some families the 3k - 4k was better spent going towards another bedroom to actually live in, than some eaves. Just my 2c. Way too diplomatic Joles... Thats what I was trying to say above Re: Eaves - The Final Verdict - You Decide! 60Nov 18, 2008 9:31 pm Did you just call me diplomatic Mattwalker? Take that back!!! I am an opinionated b*tch thank you very much! I leave you to fend for yourself, figure things out yourself. Terrence Malick I thought this would be a popular question but I haven't been able to find any similar posts. Perhaps I'm wording my searches wrong? When you have car insurance and the… 0 6624 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5879 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 |
