Browse Forums General Discussion 1 Nov 08, 2008 3:54 pm hi to all . new to this site looks very helpfull so far. im in process of desing a double garage /workshop/granny flat thinking of going steel frame like in the kit homes and putting the polystyrene foam with the render coat finsh (as i dont like the steel colourbond finsh) or maybe the heble paneling. my ? to all has anybody out there had any experiance with these products. or would it be cheaper and easyer to do brick or besser block? any ideas thanks . Re: timber frame or steel frame for double garage/granny flat 2Nov 08, 2008 4:12 pm Whats wrong with a timber frame?
I have just posted some links about polystyrene cladding in another thread https://forum.homeone.com.au/viewtopic.p ... highlight= Re: timber frame or steel frame for double garage/granny flat 3Nov 10, 2008 10:40 am If your worried about termites, you can use the T2 blue pine framing - its termite treated (only) and is only about 12% dearer than normal pine. Re: timber frame or steel frame for double garage/granny flat 4Nov 11, 2008 4:14 pm thanks for the info ive no problems with timber just thought with the steel i could do it myself .im only around corner from a company called austech external building products they have the poly cladding so will check out there showroom also a lot depends on local council. I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13904 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7222 |
