Browse Forums General Discussion Re: Concrete slab next to the entrance into garage worn out 2Dec 09, 2024 2:49 am Not likely. A 20-year-old concrete slab should still be structurally sound unless it’s showing major cracks, sinking, or significant wear. If it’s just cosmetic wear, you could patch it up or resurface it. If you're worried, a quick check by a concreter could put your mind at ease. Building Standards; Getting It Right! Make sure you don’t dig below footing base level, so you don’t undermine your foundation. Also the backfilling of trench need to allow for stormwater to drain away… 1 11580 You need to install drainage in the 8 inch area. You can try one of the drainage cells that can go in narrow spaces along your garage wall with Geofabric protection and… 1 10514 I am Reading it. I have also informed my insurance company and they are sending a plumber to investigate. 53 84154 |
