Browse Forums General Discussion 1 Oct 07, 2024 3:50 pm Hi All, Inspected my tenanted property after about four years and have observed some serious cracking in several tiled areas of the house (one side of the house). I suspect this is due to movement, although I haven't seen too much evidence of movement from the naked eye/plaster damage. I will check with a level for a better idea. Trying to best understand what my options are and how I could keep this place ticking over with tenants for about 10 years? I want to avoid restumping/big structural works as it is 50 year old house that I will either sell or redevelop in about ten years. Could a floating floor/levelling solution approach be appropriate here? Are there any lino-type products that could be suitable? I could re-tile but understandably run the risk of more movement and cracking again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Major tile damage - kitchen, bathroom and laundry 2Oct 07, 2024 4:30 pm Do you know what type of flooring is under the tiles? It looks like it's the incorrect sub-flooring or installation in the first place that has caused the issues with the tiles rather than movement necessarily, however without seeing it first hand and knowing all the details it's impossible to say. You could just rip up the existing tiles, then give the floor a rough sand to remove any tile adhesive and then install hybrid flooring or sheet vinyl, both are water proof. The hardest area will be the bathroom as there is normally waterproofing involved and some type of fallto drains. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Major tile damage - kitchen, bathroom and laundry 3Oct 07, 2024 4:36 pm Thanks Chippy, I'll have a closer look in a couple of days but believe it's hardwood on concrete stumps. I suspect the tiles have been there for many years and only the last four have the cracks really taken off. Re: Major tile damage - kitchen, bathroom and laundry 4Oct 09, 2024 3:37 pm It doesn’t look like its movement cracks or unsuitable substrates. It does however look like something heavy was moving over from one opening to another. The location of cracks on the floor supports this. Re: Major tile damage - kitchen, bathroom and laundry 5Oct 09, 2024 4:21 pm Thanks and agreed, I was initially very suspicious that the tenant had caused this. The only thing that's throwing me is I'm getting similar cracking in the bathroom and toilet (separate to each other)... unless it's been done maliciously... Hi we are looking for some advice please? We have these Portuguese tiles through our bathroom, toilet and laundry and also a small hall that connects these rooms. We are… 0 7689 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 27744 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 29197 |
