Browse Forums General Discussion Re: Warranty advice regarding the damage caused by storm water pipe not connected to silt pit 5Sep 01, 2024 9:32 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Warranty advice regarding the damage caused by storm water pipe not connected to silt pit 8Sep 01, 2024 10:59 am Eng. B A If you are going through the litigation, then you may need an independent professional forensic engineer to document the damage, the cause of damage and repair recommendations. Thank you, Eng. B A, Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 20828 Hi all, I have a lovely two story mid century house built 1962 with flat roof, box gutters and wide eaves. Unfortunately a tree came down on one corner and damaged a 4m x… 0 7994 Hi, I´m in the middle of planning a renovation in a unit, level 18. At the moment the kitchen sink is directly connected to one vertical soil stack, and it´s the only… 0 8042 |
