Browse Forums General Discussion 1 Aug 05, 2024 8:42 pm I enquired with my local water authority and no permit required if relocating under 600mm. I plan on doing this myself on a weekend. Tap and meter. How hard is it ? I read the inline pipe is 25mm poly and therefore can be clamped while I relocate the meter. I plan on soldering the connections and not using shark grips. May even put it underground. Re: How hard is it to relocate the front yard water meter ? 3Aug 06, 2024 1:41 pm You have to make application to move the meter and get permission from the water authority then the works have to be carried out by a licenced plumber. It is most definitely not a DIY job. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 5Aug 06, 2024 9:08 pm chippy You have to make application to move the meter and get permission from the water authority then the works have to be carried out by a licenced plumber. It is most definitely not a DIY job. Less than 600mm relocation does not require a permit. Re: How hard is it to relocate the front yard water meter ? 6Aug 06, 2024 9:58 pm evange chippy You have to make application to move the meter and get permission from the water authority then the works have to be carried out by a licenced plumber. It is most definitely not a DIY job. Less than 600mm relocation does not require a permit. What state are you in? Regardless, you still need to be a licenced plumber to carry out the works. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 7Aug 06, 2024 10:11 pm evange chippy You have to make application to move the meter and get permission from the water authority then the works have to be carried out by a licenced plumber. It is most definitely not a DIY job. Less than 600mm relocation does not require a permit. I'm guessing Victoria as it's the only state to allow a small move without an application. Works need to be completed by a licenced plumber. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 8Aug 06, 2024 10:47 pm evange Your account says your in ACT. If that's correct Icon water has to carry out the works Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 10Aug 07, 2024 2:06 pm evange chippy You have to make application to move the meter and get permission from the water authority then the works have to be carried out by a licenced plumber. It is most definitely not a DIY job. Less than 600mm relocation does not require a permit. Anything upstream of the connection between the meter and the line going to your house belongs to the relevant water authority and messing about with it could potentially introduce contamination to the supply of other users. You need a licenced plumber. If you do a DIY I can see a huge fine coming Re: How hard is it to relocate the front yard water meter ? 12Aug 07, 2024 3:58 pm Althom evange chippy @evange Your account says your in ACT. If that's correct Icon water has to carry out the works Correct. So not a DIY job at all then It's illegal to do electrical work on your home, route drainage and do gas fittings, do undersink plumbing, route an outside tap etc even fill your pool. Yet DIY do them every single day of the week. Thanks for your contribution. Re: How hard is it to relocate the front yard water meter ? 14Aug 07, 2024 10:48 pm evange Althom evange Correct. So not a DIY job at all then It's illegal to do electrical work on your home, route drainage and do gas fittings, do undersink plumbing, route an outside tap etc even fill your pool. Yet DIY do them every single day of the week. Thanks for your contribution. Dude, don't try and do it on your own. How do you even plan to isolate the water while you carry out the work. You can't "clamp" a main water feed. That alone tells me you have no idea. This is from the Icon water website: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 15Aug 07, 2024 10:54 pm evange It clearly states that the works are to be carried out by Icon Water. You make application, they do the work. Don't do illegal plumbing work, particularly on water mains. You have the potential to make a right mess of it and embarrass yourself. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How hard is it to relocate the front yard water meter ? 16Aug 18, 2024 9:53 am chippy @evange It clearly states that the works are to be carried out by Icon Water. You make application, they do the work. Don't do illegal plumbing work, particularly on water mains. You have the potential to make a right mess of it and embarrass yourself. Point taken. I relocated it last week and was successful. thanks for the info. Our relationship with the owner is good, but I'm not sure if I want to impose putting a pole on their property. Your conversation with your neighbour must have gone well… 4 11742 Having been through a manhole ...let's call it "situation" recently with Sydney water, I think there is a zero percent chance of you relocating this. The reason being as… 2 3469 there should be ss cable so you can pull up bore pump for service 1 4444 |
