Browse Forums General Discussion 1 Jul 31, 2024 8:12 pm Re: Why there are white stain on the brick wall? 2Aug 01, 2024 5:47 am It doesn’t fit a pattern of efflorescence. It looks like an effect of a harsh chemical on the brick and mortar. You can see the brick mortar in the area has been eaten away. Look for the chemicals in your floor cleaner. Make sure they are safe to use over tiles, grout, mortars and bricks. If you also have pets, pets urine on long term have bad effect on grout and brick mortar. Re: Why there are white stain on the brick wall? 3Aug 01, 2024 9:47 pm Eng. B A It doesn’t fit a pattern of efflorescence. It looks like an effect of a harsh chemical on the brick and mortar. You can see the brick mortar in the area has been eaten away. Look for the chemicals in your floor cleaner. Make sure they are safe to use over tiles, grout, mortars and bricks. If you also have pets, pets urine on long term have bad effect on grout and brick mortar. Hmm, this is quite puzzling. No one has been living in that bedroom, and we haven't used any chemicals to clean the floor. In fact, those areas are under a balcony that hasn't been cleaned for a long time since no one is living there. We also don't have any pets. What steps can I take to fix this problem? Re: Why there are white stain on the brick wall? 4Aug 01, 2024 11:22 pm gamesover Eng. B A It doesn’t fit a pattern of efflorescence. It looks like an effect of a harsh chemical on the brick and mortar. You can see the brick mortar in the area has been eaten away. Look for the chemicals in your floor cleaner. Make sure they are safe to use over tiles, grout, mortars and bricks. If you also have pets, pets urine on long term have bad effect on grout and brick mortar. Hmm, this is quite puzzling. No one has been living in that bedroom, and we haven't used any chemicals to clean the floor. In fact, those areas are under a balcony that hasn't been cleaned for a long time since no one is living there. We also don't have any pets. What steps can I take to fix this problem? It looks like efflorescence to me. I wonder if it's a waterproofing issue on the balcony. The moisture is seeping through the screed bed on the balcony and finding it's way out down the face of the walls underneath. If it is you won't be able to fix it without redoing the waterproofing. Even if you clean the efflorescence off it will just come back as it pulls salts out of the screed bed. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Why there are white stain on the brick wall? 5Aug 01, 2024 11:47 pm chippy gamesover Eng. B A It doesn’t fit a pattern of efflorescence. It looks like an effect of a harsh chemical on the brick and mortar. You can see the brick mortar in the area has been eaten away. Look for the chemicals in your floor cleaner. Make sure they are safe to use over tiles, grout, mortars and bricks. If you also have pets, pets urine on long term have bad effect on grout and brick mortar. Hmm, this is quite puzzling. No one has been living in that bedroom, and we haven't used any chemicals to clean the floor. In fact, those areas are under a balcony that hasn't been cleaned for a long time since no one is living there. We also don't have any pets. What steps can I take to fix this problem? It looks like efflorescence to me. I wonder if it's a waterproofing issue on the balcony. The moisture is seeping through the screed bed on the balcony and finding it's way out down the face of the walls underneath. If it is you won't be able to fix it without redoing the waterproofing. Even if you clean the efflorescence off it will just come back as it pulls salts out of the screed bed. Thanks so much for your replies. It reminds me the inspector sent me the inspection report with below content: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does it mean I need to redo waterproofing and tiles on the balcony? Since I think waterproofing is under the tile, if redo waterproofing, I have to replace the tiles? Re: Why there are white stain on the brick wall? 6Aug 02, 2024 5:29 am I still believe it’s a chemical attack on the brick and mortar. Balcony Waterproofing failure would do damage like that. In addition you would see a leak in the room underneath during rainfall and you would know something wrong in the waterproofing. How old is the house and when did you start noticing the stain? Re: Why there are white stain on the brick wall? 7Aug 02, 2024 10:56 am Eng. B A I still believe it’s a chemical attack on the brick and mortar. Balcony Waterproofing failure would do damage like that. In addition you would see a leak in the room underneath during rainfall and you would know something wrong in the waterproofing. How old is the house and when did you start noticing the stain?
I searched on Google, and some posts suggested that Shower Plug is effective in stopping leaks without redoing the waterproofing. Do you think it will work for me? By the way, I took more pictures of the balcony. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for the detailed comments chippy, I'll use this as a guide. 3 1813 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 5896 I have a new Canadian Ash front door and frame. I need some advice. Can i coat Feast Watson ‘Exterior Stain and Varnish’ (FW) (turps based) over a clear turps based… 0 1858 |
