Browse Forums General Discussion 1 Jul 28, 2024 2:03 pm I am looking at getting a wall shed to go on the concrete around the house. The concrete slab is 100mm thick. My concern is, concrete slab slopes 50mm over 1m to ensure water flows away from the house. Will this be an issue when installing Re: Installing shed on sloping concrete slab 2Jul 30, 2024 6:22 pm When I worked on leveling my shed, I found that using adjustable base plates or shims was a pretty effective way to stabilize it. Another approach I tried was building a raised platform on the concrete slab first. For that, I used treated timber and metal framework, making sure everything was securely anchored. It’s also important to make sure the shed’s base is sealed properly to keep out any water. One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 6613 0 11933 |
