Browse Forums General Discussion 1 Jun 30, 2024 9:41 am I am getting my alfresco area raised with concrete and extended outside of the roof line, after which it will be tiled to match the height indoors (but with a 30mm gap to protect weep holes). My question is, what fall to have on the tiled area? Need to consider: - I want to keep the tiles level with the house (if possible) - The inbuilt bbq and masonry wall should be level What should I tell the concreter to do? Appreciate any advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What fall on tiled alfresco? 2Jun 30, 2024 3:14 pm I assume you meant 30mm step down from the house slab. If not make sure you have adequate step down to outside area so you don’t get stormwater inside house. Please see below from the BCA. Surface drainage Section 3.1.2.3 of the BCA states: ‘Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (see Figure 3.1.2.2); (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. (b) Slab-on-ground — finished slab heights: the height of the slab-on-ground above external finished surfaces must be not less than (see Figure 3.1.2.2); (i) 100 mm above the finished ground level in low rainfall intensity areas or sandy, well-drained areas; or (ii) 50 mm above impermeable (paved or concreted areas) that slope away from the building in accordance with (a); or (iii) 150 mm in any other case. Re: What fall on tiled alfresco? 4Jun 30, 2024 6:21 pm A gap will direct stormwater under the house foundation which could cause movement and building cracks. It’s not recommended and it’s non-compliance with building code to have the outside slab level similar to house slab as it’s potentially could direct stormwater to inside the house. The code as mentioned require at least 50mm step down with a slope away in the exterior slab as previously stated. Re: What fall on tiled alfresco? 6Jul 01, 2024 5:50 pm As mentioned, it’s not recommended to level the outside with inside slab. It’s also recommended to fill any gaps between outside slab and building with flexible sealant to avoid any water ingress and future movements. Thanks for replying. In my case, there’s no house for the weather to run back on to. There’s just a free fall to the ground, 3 m below. The balcony has 3 posts at the… 11 16447 No. You only have to restrict the opening of any window when the opening starts below 1700 finished floor height or there is a transom or other climbable surface (toilet,… 1 10715 For those following along, the engineers have kindly come to the party and will be implementing a solution that should ensure adequate fall to the house connection. This… 8 14127 |
