Browse Forums General Discussion Re: Downpipe dischargin next to carport wall 3Jun 14, 2024 9:03 am Eng. B A You need to connect the pipe to a legal point of discharge which is supposed to take this amount of stormwater water and discharge it safely. Don’t rely on soil properties as even sandy soil may have a slight percentage of clay or fine material that may gets washed out overtime and cause movement in buildings. Thanks so much! So i really need to run this pipe into a soakwell? Any idea of how much it costs to install a small soakwell with piping? Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 6593 It will depend on whoever does the inspection and his pick up to details. 5 2025 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 22012 |
