Browse Forums General Discussion 1 May 27, 2024 7:20 pm Hi - When laying 3600x800 sheets to the perimeter of the building with joist spacing at 450crs the end of the sheet doesn't land on a joist spaced at 450 (unless you center the joist to the perimeter beam) what would you normally do here, put in another joist @ 3640 so the end lands centre to that joist, but then your spacing becomes 50mm out of whack for that one. Obviously I want to avoid cutting the sheet back to the nearest joist. Thanks! Re: Structafloor/subfloor laying question 3600x800 sheets. 2May 28, 2024 8:05 am ryanmagic Hi - When laying 3600x800 sheets to the perimeter of the building with joist spacing at 450crs the end of the sheet doesn't land on a joist spaced at 450 (unless you center the joist to the perimeter beam) what would you normally do here, put in another joist @ 3640 so the end lands centre to that joist, but then your spacing becomes 50mm out of whack for that one. Obviously I want to avoid cutting the sheet back to the nearest joist. Thanks! You need to cut your sheets and stagger them if that makes sense Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Structafloor/subfloor laying question 3600x800 sheets. 3May 31, 2024 12:40 am As above, you will need to trim your sheet to land on the joist, also make sure you are running your length at right angles to the joists We are Expert Consultant's, and we are here to help. Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4440 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 8238 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 15668 |
