Browse Forums General Discussion 1 May 06, 2024 11:28 am Hey everyone, I need some expert advice on a roof leak issue. During heavy rain, I have this weird roof leak issue, where water droplets drip through one specific downlight. This downlight is located under solar panels on the roof. I've had the roof thoroughly checked multiple times and no issues (broken tiles etc.) found. The only difference between this downlight is that this downlight isn't completely latched to the roof due to timber blocking it (builder issue). Nearby, there's a ducted aircon pipe, although it's not directly above the downlight. I'm wondering if this could be causing a condensation effect when the aircon runs on heating mode and there's a temperature difference between inside and outside. Any suggestions on how to further investigate this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof Leak Investigation 3May 07, 2024 8:53 am pay some money and get a roof leak specialist Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 26682 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 16081 6 17485 |
