Browse Forums General Discussion 1 Apr 05, 2024 5:47 pm Currently having some skylights installed in raked ceiling. The builder had left internal moveable scaffold for the roof plumber to have access to ceiling. A few days until plumber arrives. Then plaster after that, the re paint room. Is there any problem with doing the paint cut in ceiling to high walls while I have access with scaffold. Then the rolling after plaster of ceiling in a few weeks? Could I have advice please Re: Painting help please 2Apr 06, 2024 11:56 am Buzzbuzz Currently having some skylights installed in raked ceiling. The builder had left internal moveable scaffold for the roof plumber to have access to ceiling. A few days until plumber arrives. Then plaster after that, the re paint room. Is there any problem with doing the paint cut in ceiling to high walls while I have access with scaffold. Then the rolling after plaster of ceiling in a few weeks? Could I have advice please using the builders scaffold may void builders' insurance if you have a fall or cause any damage to ongoing work...check with your own and builders insurers before using their equipment and make sure that you have their answers in writing Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can itβs already a more thinner product than a final coat paint Also in water base Water or… 3 5284 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8724 Thankyou so much π I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK π 2 7570 |
