Browse Forums General Discussion 1 Jan 14, 2024 6:17 pm So our house is a newer build, and have noticed this material in the stormwater drain. Not sure if someone has been dumping things in it, or if there has been some malpractice during build process. Any insight would be greatly appreciated. https://imgur.com/a/LWYqUDi Re: Finding materials in stormwater drain 2Jan 15, 2024 8:38 am in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most part there shouldnt be a huge issue unless somone pours concrete down them. Theyre designed to catch stuff and be periodically cleaned out. A bigger issue may present if stuff like rocks and building waste is found in the actual drains Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9760 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 9224 Hi Kateo, Are you able to spare any of the tiles? Thanks Tony 10 12170 |
