Browse Forums General Discussion 1 Dec 18, 2023 7:01 pm Building a Hampton facade home with Clarendon and we are very close to handover, was meant to be last week. I raised an issue a few months back and some work was done, but then it rained and exposed far more than I bargained for. My eaves are not square and point downward. The guttering is at the limits and I had water over an inch deep in the gutter. When it rained the guttering overflowed in spectacular fashion. I discussed that the eaves were pointing downward and not square and there is no way water can run uphill. They fixed one and left the other and said tested and all working fine now. A quick check revealed the downpipes were blocked at the gutter due to only having a few 15mm holes cut into the gutter entering the 90mm pipe. Has anyone seen this before? Would you expect your eaves to be angled towards the ground instead of square? The downpipes are around the corner and with the eaves pointing down its a lot of water being held, but I have been assured water is not sitting in the eaves. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Clarendon Eaves and Guttering Issue 2Dec 18, 2023 7:27 pm Just when you think you have seen everything..... What region are you building in and what is the gutter style and size? 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Clarendon Eaves and Guttering Issue 3Dec 18, 2023 8:23 pm SaveH2O Just when you think you have seen everything..... What region are you building in and what is the gutter style and size? It is certainly nothing i have seen before. Building in NSW and the gutter is half-round, looks like 150mm. Not much water getting through. Re: Clarendon Eaves and Guttering Issue 5Dec 22, 2023 11:57 am The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this! Do the gutters pool water after it stops raining? Although it's hard to see in the photo, the gutter does appear to have overflow slots. Is this correct? Sloping a gutter downwards at the front reduces a gutter's capacity, thereby quite possibly/probably deeming the gutters to be no longer compliant with the NCC part 2 (BCA) regulations that apply to your gutter's required capacity for the roof areas that drain to each downpipe during a 1:20 year annual exceedance probability (AEP). I would be contacting the DFT for advice. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. I am about to replace rusted guttering and eventually paint the roof on my rental property. I would like to go with a medium grey (probably Basalt) colour and had planned… 0 1361 I would replace the nails with timber or gyprock screws. They definitely wont come out 2 1404 Correct. External the eaves will sit on top of the window frames, internally there will be 3 courses to the ceiling. Those details are from our house. We went with 28c… 5 622 |
