Browse Forums General Discussion 1 Nov 01, 2008 8:27 am Hi guys
I have a question regarding laying laminate flooring. We have left the skirting boards off to attach after boards are down. We are going to do it ourselves to save money. We will cut under the door jams to slide the boards under them as to avoid putting trim around them. What I can't workout is when you come to your last board, how do you get it under the door frame at the end without creating a gap? Because you have to slide the last board back then forward to lock into place you will be left with a gap where you have had to cut further into the door frame. I hope this makes sense because it is doing my head in. Any advice much appreciated. Treechangers Will we ever get there? Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4935 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1938 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4332 |
