Browse Forums General Discussion Re: rust on house I Beams 2Oct 27, 2023 9:54 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: rust on house I Beams 7Oct 30, 2023 8:29 am If you want peace of mind you need to get an actual structural engineer to look at it as there are a number of variables that determine how bad the rust will get and in what time frame. Re: rust on house I Beams 8Oct 30, 2023 12:07 pm ![]() If you want peace of mind you need to get an actual structural engineer to look at it as there are a number of variables that determine how bad the rust will get and in what time frame. Thanks can you tell from the photos if the beams are galvanised l am getting a bulding inspector next week to have a look , if he says it might be a problem then l will get a structual engineer. L was thinking surely as its only 12 years old and thick beams it cannot be worse then surface rust that can be easily treated.the nighmare case is that the rust is so bad the beams neeed to be replaced which would cost a fortune Re: rust on house I Beams 9Oct 30, 2023 12:19 pm ![]() ![]() If you want peace of mind you need to get an actual structural engineer to look at it as there are a number of variables that determine how bad the rust will get and in what time frame. Thanks can you tell from the photos if the beams are galvanised l am getting a bulding inspector next week to have a look , if he says it might be a problem then l will get a structual engineer. L was thinking surely as its only 12 years old and thick beams it cannot be worse then surface rust that can be easily treated.the nighmare case is that the rust is so bad the beams neeed to be replaced which would cost a fortune The original photo doesn't look galvanised but I can't really tell with the other photos. If the conditions are okay then I agree with the handyman that you will be gone before it's an issue. But I don't say that with much confidence as I'm not an engineer TRe: rust on house I Beams 10Oct 30, 2023 12:35 pm Thanks ,the first photo up the top of the page is not my house just a photo from the internet, the second two photos are my house, do those two look galvanised or impossible to tell, maybe try zooming in close Re: rust on house I Beams 11Oct 31, 2023 7:21 am Its hard to help someone who does not listen, have you checked your permit engineering drawings to see whether your structural steeel is supposed to be galvanised or primed? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: rust on house I Beams 12Oct 31, 2023 10:18 am ![]() Its hard to help someone who does not listen, have you checked your permit engineering drawings to see whether your structural steeel is supposed to be galvanised or primed? L dont know if l still have them or was ever given them , l will check. Re: rust on house I Beams 13Nov 01, 2023 11:53 am ![]() Its hard to help someone who does not listen, have you checked your permit engineering drawings to see whether your structural steeel is supposed to be galvanised or primed? l looked through the papers l was given when the house was built all l could find was DESIGN STANDARDS AS4100 1998 Steel Structures AS1170 2002 Structural design actions loading code STANDARD SPECIFICATION FACADE" "Fully galvasnized steel subfloor- for a sold feel underfoot" It says " fully galvanized steel subfloor , does that mean everyrthing was galvanzies, including the posts and I beams and joists the only place l notice rust is on the i beams Re: rust on house I Beams 14Nov 01, 2023 12:09 pm You built the home 12 years ago, there must be a full set of drawings and a specification with your building permit, if you don’t have it buy a copy from the council or the building surveyor, then you will know what it should have been. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: rust on house I Beams 15Nov 01, 2023 12:54 pm ![]() You built the home 12 years ago, there must be a full set of drawings and a specification with your building permit, if you don’t have it buy a copy from the council or the building surveyor, then you will know what it should have been. Hi just to update , got a building inspector to have a look today , he has 30 years experience and he said the I - BEAMS are not Glavanized but its nothing to worry about just some surface rust and not structural rust , he said theres no need to worry for another ten years then get someone to go under the house and scrap off the rust and paint the beams then but no need to do anything now, He said the steel post that support the i Beams were galvanized but he said the i Beams were not galvanized but he said because they are so large and strong the surface rust doesnt matter they will last decades but he said in about ten years l should get someone to go under the house and scrap off the rust the paint he beams with paint but theres no need to do anything now. , l was thinking of spraying the beams with Ranex rust converter, is that a good idea. Re: rust on house I Beams 17Nov 06, 2023 10:17 am ![]() Why would you wait 10 years for the rust to get worse? Apply a primer, rust inhibitor now. The building inspector who has 30 years experience as a building inspector and good reviews said his sure its just a bit of harmless surface rust and nothing needs to be done for atleast ten years , he said even though the beams are non galvanized they are so thick and strong they will last decades without treatment and the steel posts underneath that also a little bit of rust but they are glavanized so they will rust really slow . But l will probably treat it in a few years to be safe, its not an urgent problem Re: rust on house I Beams 20Nov 08, 2023 10:13 am ![]() ![]() i had a stroke reading this thread why, what do you mean? I shouldn't have to explain this to you. But.... sure you dont have to do anything now. But why would you wait X years before you do do do something arguably pretty easy as a preventative so that a) you don't have to monitor, b) adress a longer term risk and c)protect your investment. Have you ever seen videos or pictures of people with medical conditions that are so gross you asked yourself "how could you let something get that bad?" This could be you in 10 years. Time will tell. if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7986 thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 3729 That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel 2 8447 |
