Browse Forums General Discussion 1 Oct 08, 2023 3:23 pm Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while for it to seep out of the floor near the basin. When we put our shower on that is quite some distance to the leak, a little bit of moisture comes out of the leak spot but not much. Could there be a broken or cracked pipe under the slab, or could tree roots be partially blocking the drain? Any thoughts are welcomed. Thanks 🙏 Please see a picture of the location of the shower and the basen to where the leaking is occurring. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 21353 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 19452 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 12533 |
