Browse Forums General Discussion 1 Sep 29, 2023 1:03 pm Hi all - i have some pests getting under my house. There are some larger points of entry which i will initally block off with Plywood, but i suspect some rodents could access the house via these ventilation gaps in my brick work (i assume they are for ventilation). Is there some product that i can use to pest proof these gaps with affecting the ventilation ? Any advice appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pest Proofing Ventilation gaps in brick veneer home 2Oct 01, 2023 6:31 am lukeb0030 Hi all - i have some pests getting under my house. There are some larger points of entry which i will initally block off with Plywood, but i suspect some rodents could access the house via these ventilation gaps in my brick work (i assume they are for ventilation). Is there some product that i can use to pest proof these gaps with affecting the ventilation ? Any advice appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Brass fly wire, you will need to cut it, shape it and jam it into brick slots Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog B, You and I know each other well outside of the forum, and I really like you. So I am not meaning any ill will by the following comments. I have been with you on this… 7 1693 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5572 5 11158 |
