Browse Forums General Discussion Re: Feature brick discoloured 3Sep 18, 2023 10:41 am ![]() ![]() Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! is it around the fireplace vent (as in is it heat that's caused the discoloration" or is it just random bricks here and there Just random bricks - house is still under construction. Re: Feature brick discoloured 4Sep 18, 2023 2:47 pm ![]() ![]() ![]() Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! is it around the fireplace vent (as in is it heat that's caused the discoloration" or is it just random bricks here and there Just random bricks - house is still under construction. hmmm id assume youll get hit with the "natural product therefore variation in colour etc" excuse. How bad are we talking? One could argue that if none of the displays or other installs of the brick show such discolouration or variations, then the ones you have are faulty/defective Good day everyone, I have two queries regarding stacked stone style facade feature tile installation. 1. I am looking for an installation price guide to install stacked… 0 16831 I always picked up a colour in the curtains to avoid a clash. I also found that darker tones of any colour added impact which is the whole point of having a feature wall. 3 20368 ![]() Hey andy8 Did you get a resolution to this? It's been a while since you posted this... I'm in a similar situation and doing a single to double storey conversion. 1. We… 1 12362 |
