Browse Forums General Discussion Re: Sewer pipes under slab 3Aug 27, 2023 11:48 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Sewer pipes under slab 4Aug 27, 2023 12:02 pm Below is a link to a post by a leading slab heave expert. viewtopic.php?p=1206402#p1206402 Also, if AS 2870 is referenced in the contract, make sure it is not only referenced to the slab which is construction. It must also be referenced as plumbing if you want to include flexible joints etc. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sewer pipes under slab 5Aug 27, 2023 1:14 pm SaveH2O Below is a link to a post by a leading slab heave expert. viewtopic.php?p=1206402#p1206402 Also, if AS 2870 is referenced in the contract, make sure it is not only referenced to the slab which is construction. It must also be referenced as plumbing if you want to include flexible joints etc. Thanks that link in particular is really useful. Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16396 To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 8333 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 19135 |
