Browse Forums General Discussion 1 Jul 24, 2023 4:15 pm Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that you have to use composite decking but if installed correctly seems like a cost-effective solution. It's also installed above the joists so less chance of rotting out your joists and bearers. Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3839 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38817 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 18265 |
