Browse Forums General Discussion 1 Jul 07, 2023 4:49 pm our house is at practical completion yet there are taps missing, no downpipes,unfinished stairs with no railings or varnish, exposed electrical wires. damaged window frames and no flashing between brickwork and windows. Also gaps in eaves under roof line. The biggest problem is that when you run the tap in the laundry there is nowhere for the water to go and it floods. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We stupidly went along with the practical completion meeting and 4 weeks down the track none of these items have been touched. We have talked to them and they always come back with the response "we are working on it, you can delay handover" All we want is for things to be done and move in? Is this normal? Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9752 Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 5027 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 8504 |
