Browse Forums General Discussion Re: Drive way channel drain 2Jun 26, 2023 7:48 pm I'd go bigger. You'll overwhelm a 150x150 if it's a steep driveway. Also look to have as open style of grate as possible. Water will sheet over the top of some of the pressed style grates if the driveway is steep. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Drive way channel drain 3Jun 26, 2023 7:53 pm chippy I'd go bigger. You'll overwhelm a 150x150 if it's a steep driveway. Also look to have as open style of grate as possible. Water will sheet over the top of some of the pressed style grates if the driveway is steep. Yeah it's what I thought as I had discussed 200x200 with the concreter yet today 8 metres of 150x150 has arrived Re: Drive way channel drain 5Jun 27, 2023 7:27 am Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for overflow that would escape down side of house before getting to the garage. Agreed overflow would be important. Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39211 Agreed. I just found out today the certifier has not given the final sign off. 2 4200 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8720 |
