Browse Forums General Discussion Re: PVC pipe through footing 3May 19, 2023 4:24 pm ![]() bridge the pipe with a bigger footing, dig down to undisturbed soil either side, wrap the pipe in 2 layers of 10mm adhesive backed foam abelflex expansion “sticky back”, then get some 12mm deformed rod to span over it, or move the pipe. don’t concrete it in or bear on it. If best on backfill it will settle and the concrete will crack your pipe. Thanks Pulse for the reply. Just to clarify, the hole extends another 400mm below the pipe, it is it just full of water due to the rain we had. I think I will wrap it as you mentioned and span over it with deformed rod to shift as much weight off the pipe as possible. Hi all, I'm excavating a footing to build a front wall next to the footpath. I've excavated the footing (8 m long, 600 wide, 600 mm deep) and there is an old sleeved gas… 0 7206 The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 12346 ![]() |
