Browse Forums General Discussion Re: Water tank for Home 2Apr 27, 2023 9:23 pm well not much to go on do you have town water and this is just to water garden or is this your only source of water what size do you plan on suburban or rural what roof size and material to fill tank Re: Water tank for Home 3May 01, 2023 2:47 pm From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some reason. They're harder to install and generally more expensive . Whereas the newer heavy duty polyethylene tanks will still last forever but they're light and strong. You can ship them in easy, transfer them into the ground much easier. I would go with a polyethylene tank, they have an extra thick corrugated walls for maximum strength making it as tough as concrete but lighter. They're one-piece construction with no joins etc, which means they have no weak points so will last long. Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11752 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 2312 You just need the gutter and downpipe sizes to be compliant with the NCC for the roof area harvested and have the downpipes connected to a LPOD. You need to ask your… 1 10741 ![]() |
