Browse Forums General Discussion 1 Jul 16, 2023 10:34 am I have a raised house and want to create an area under the house that opens up out onto the yard. There are vertical wooden slats fixed to horizontal beams. The horizontal beams are attached to the vertical stumps. As per the photo. Can the horizontal beams be removed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 890 THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28264 if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7456 |
