Browse Forums General Discussion 1 Apr 18, 2023 10:10 am Hi Sorry about the silly question; we are first-home buyers looking to buy our first property and learning a lot. One property we are interested in has a lot of external wall cracks outside (double brick), and the current owner seems to have done a lot of self-patching (?) We spoke with two builders; one builder said it is all good and nothing urgent since there is no internal cracking it is nothing urgent the outside brick is just a facade as the interior brick is holding all the weight (?) Another builder said we should consider doing brick rendering/ join and resolve it sooner than later. We are planning to repaint the external brick in the futre and thinking of fixing it then (3-5 years). Or is this something we should get fixed ASAP? Thank you in advance (photos below) Regards https://imgur.com/a/bl2S036 In my opinion, this is because the posts are built in control joint way. Control joints are normally placed in non-structural floating slab at maximum 3.0m spacing. So if… 3 6096 Ground movement due to stormwater discharge from disconnected downpipe in combination of lack of isolation joints between the external pavement and building. This is from… 2 8690 Pelli69 It is super normal for new homes to move as they settle in over the first year or two. Usually we find that some minor cracking may occur in gyprock, especially… 2 7641 |
