Browse Forums General Discussion Re: Can I install a pendant light to ceiling? 2Mar 24, 2023 4:01 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Can I install a pendant light to ceiling? 3Mar 24, 2023 8:51 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Can I install a pendant light to ceiling? 4Mar 24, 2023 10:34 am Ashington Homes Venn Diagram Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'd like to ask if I'm able to add pendant lights to my rooms (bed 2, 3, 4 and leisure area) once the house is handed over. This is for the 2nd floor. We were told by the electrical consultant (about a year ago) that we're able to do work "easier" since it's on the 2nd floor but not the ground floor. Red are standard electrical point (Fluorescent Batten Holder Light Point & Switch) Green are electrical point with timber noggin for pendant lights. We'll add more red points for normal down lights. But thinking if it's easy to drill hole to the ceiling and add pendant lights since the wiring is already there or replace the red points and add pendant lights? Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon Ashington Homes Venn Diagram Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'd like to ask if I'm able to add pendant lights to my rooms (bed 2, 3, 4 and leisure area) once the house is handed over. This is for the 2nd floor. We were told by the electrical consultant (about a year ago) that we're able to do work "easier" since it's on the 2nd floor but not the ground floor. Red are standard electrical point (Fluorescent Batten Holder Light Point & Switch) Green are electrical point with timber noggin for pendant lights. We'll add more red points for normal down lights. But thinking if it's easy to drill hole to the ceiling and add pendant lights since the wiring is already there or replace the red points and add pendant lights? Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon @ashington Homes Thanks! If the place doesn't have the extra timber, will it be easy to add one later? If not, what's the maximum weight usually a ceiling is able to support without the timber? Re: Can I install a pendant light to ceiling? 5Mar 24, 2023 12:02 pm Venn Diagram Ashington Homes Venn Diagram Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'd like to ask if I'm able to add pendant lights to my rooms (bed 2, 3, 4 and leisure area) once the house is handed over. This is for the 2nd floor. We were told by the electrical consultant (about a year ago) that we're able to do work "easier" since it's on the 2nd floor but not the ground floor. Red are standard electrical point (Fluorescent Batten Holder Light Point & Switch) Green are electrical point with timber noggin for pendant lights. We'll add more red points for normal down lights. But thinking if it's easy to drill hole to the ceiling and add pendant lights since the wiring is already there or replace the red points and add pendant lights? Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon Ashington Homes Venn Diagram Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'd like to ask if I'm able to add pendant lights to my rooms (bed 2, 3, 4 and leisure area) once the house is handed over. This is for the 2nd floor. We were told by the electrical consultant (about a year ago) that we're able to do work "easier" since it's on the 2nd floor but not the ground floor. Red are standard electrical point (Fluorescent Batten Holder Light Point & Switch) Green are electrical point with timber noggin for pendant lights. We'll add more red points for normal down lights. But thinking if it's easy to drill hole to the ceiling and add pendant lights since the wiring is already there or replace the red points and add pendant lights? Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon @ashington Homes Thanks! If the place doesn't have the extra timber, will it be easy to add one later? If not, what's the maximum weight usually a ceiling is able to support without the timber? if you can screw it in a rafter you will be fine, it's just that often the location of the light is in between a rafter so we just add some extra timber so you have something to screw it too and you have the flexibility to locate it whenever you want. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Can I install a pendant light to ceiling? 6Mar 24, 2023 12:07 pm Ashington Homes Venn Diagram Ashington Homes Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon Ashington Homes Hey Venn How are you? The simple answer is yes you certainly can, the only issue you have to be aware of is the weight of the pendant and whether or not it needs blocking out in the ceiling ( ie extra timber) to support the weight. For a half decent electrician running cables is easy. Even downstairs, you will be amazed at how easy it is to add extra lights and speakers to ceilings. It is just a matter of skill being able to snake cables. Anyhow all the best. Simeon @ashington Homes Thanks! If the place doesn't have the extra timber, will it be easy to add one later? If not, what's the maximum weight usually a ceiling is able to support without the timber? if you can screw it in a rafter you will be fine, it's just that often the location of the light is in between a rafter so we just add some extra timber so you have something to screw it too and you have the flexibility to locate it whenever you want. Ic so if we can’t easily add the timber it will mean it will not be possible to add a pendant light in the room right? I am just afraid the pendant light added will fall off the ceiling without any fastening to a timber Re: Can I install a pendant light to ceiling? 7Mar 24, 2023 12:20 pm Venn, For small pendants you can get some plasterboard anchors, that hold up to 10kg which should be sufficient, but for larger items I would cut a hole add timber and patch it. Most painters can do this for you and you just pay them day labour. Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. what's the rationale on this? In my mind, the risk weepholes mitigate isn't solved by acrylic render. 9 33156 Many thanks for your reply. Yes I am concerned with the work done. I have another problem with my contractor and I hope this next investigation and review with the… 2 11822 Curtain Ceiling Track Installation Advice? With the last 20cm of the ceiling track on an angle, could it be as simple as: 1. Bending the track slightly to match the… 0 11764 |
