Browse Forums General Discussion Re: Laundry Tiles Height Level 2Mar 11, 2023 11:07 am Are you talking about plain wall or around benches? Full height tiling looks great but is expensive. Basic tiling labour only cost us around $70/sm++ and tiles were around $30/sm++. Most volume display homes only do the half height due to the cost. If you have benches with overheads I’d definitely tile between them. I don’t like the half height tiling personally - I reckon it’s either full height or nothing. Half height makes you realise it’s not full height (as silly as that sounds). In wet areas where we didn’t have full height tiling we used a 300mm high ‘skirting’ tile. Move your linen into laundry and access laundry from your present linen space 1 8194 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17728 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6698 |
