Browse Forums General Discussion 1 Feb 27, 2023 8:15 pm Yes, this is gross misuse and against building codes. But hypothetically speaking, if there is a toilet located on an elevation (say 0.5m above ground level) and there is a sewer inspection point basically next to it on the ground, what would happen if that toiled was plumed into the inspection point other than an inspector having a heart attack? Is there a reason those are always sealed other than same why we need a trap on a straight pipe? Cheers. Re: Connecting waste to sewer inspection point. 3Feb 28, 2023 5:41 pm Sewer of course. We aren't barbarians. I believe it's "downstream". (Isn't everything normally downstream of vent pipe to make the vent work effectively?) In the wall next to the IO is a plumbing duct from the bathroom upstairs, I imagine that is what the inspection point opens to. Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6576 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 24016 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11829 |
