Browse Forums General Discussion 1 Oct 27, 2008 1:13 am I came across this document showing the thermal capabilities of hebel
http://www.universaldesignrenovations.com/wordpress/wp-content/uploads/2008/05/hebel-thermal-properties.pdf note tha last page it has a comparison over core filled block & brick, it states "Internal and External Surface Film Resistances are not included in the following examples." which to me I would think means things like render & plasterboard yet for hebel it states "200mm CSR Hebel AAC Block Wall with 2-3mm external texture coating + 10mm Gyprock® plasterboard internal lining." but it doesnt state the '2-3mm external texture coating + 10mm Gyprock® plasterboard internal lining.' bit for the results of the other test subjects It appears to me to be a very bias test presented to get results favourable toward hebel,, anyone else see it that way. also I always thought core filled blockwork had good thermal resistance. Re: does this appear to be misleading result to you by hebel 2Oct 27, 2008 7:34 am Surface film resistance refers to the thin layer of air that "sticks" to the outside of surface.
Haven't read the article, but I hope this helps. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: does this appear to be misleading result to you by hebel 3Oct 27, 2008 6:24 pm ok but disregarding that sentance it only states that the hebel has been tested with render & plasterboard indicating maybe the other methods were tested without these and as such would not give as good a resistance. Re: does this appear to be misleading result to you by hebel 4Oct 29, 2008 11:01 pm It would appear that the comparisions are not like for like.
That's why I like articles like these. As basic as the tests in this are - at least is should be a bit less biased - one would hope. http://www.dab.uts.edu.au/ebrf/research/comparative_analysis_of_thermal_performance.html But as will any house design, the material alone is not the only thing that makes it comfortable, shading, etc eaves, etc etc all needs to be considered. Steve Re: does this appear to be misleading result to you by hebel 5Oct 29, 2008 11:05 pm Bah! to your eaves ... I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5871 1 6601 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 |
