Browse Forums General Discussion 1 Nov 14, 2022 9:02 am Hi All, Long story, have paid a fortune to have back fill dug up and retaining wall sealed and waterproofed (besser block) We used a commercial product (HPMA Sealtite AR) from Aldridge which is a PU membrane and the equivalent primer underneath. For a small section the landscaper for the second stupidly used a Water based product on top of the PU membrane. This section has never quite dried and is almost like an oily/tacky/tar sitting on surface of membrane. Is there a simple way/chemical to almost dissolve the WB product? I dont know which product it is but could find out. Given its a small section externally with one thick coat already on of PU plus plenty of drainage should I even bother? Also one more Q.... Is there something I can use to remove dried WB bitumen product off render? careless trades needing to be supervised like small children unfortunately, Thanks in advance Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7224 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21312 DIY, Home Maintenance & Repair fair question about the slope. Re soil I mean that it doesn't look like reactive clay which swells and shrinks with wetness/dryness. If the floors in your house are… 3 20083 |
